List of Services
Below is the full list of services available in the Wialon system.
Service
Description
Activated unitsAllows you to charge off only the cost of activated units from the account balance.
Admin fields
Allows you to create admin fields in the properties of the unit, user, or group (on the Custom fields tab); defines the available quantity (in total) and the cost of such fields.
Advanced reports
Allows you to use advanced reports, i.e., reports on users, drivers, trailers, passengers, and geofences as well as groups of units, drivers, trailers, passengers, and geofences (except for the Log table for users and unit groups). Works within the Reports module.
App for iOS and Android
Activates access to the application for iOS and Android.
Commands
Activates the corresponding tab in the Unit properties dialog; defines the quantity (total for all units) and cost of commands.
Create resources
Activates the button to create resources and accounts on the corresponding panel (available only in CMS Manager).
Create unit groups
Activates the button to create unit groups in the corresponding panel.
Create units
Activates the button to create units in the corresponding panel.
Create users
Activates the button to create users in the corresponding panel.
Custom fields
Activates the corresponding tab in the properties of the unit, user or group; defines cost and quantity (in total) of custom fields; does not affect drivers and trailers.
Dashboard
Activates the Dashboard tab.
Drivers
Activates the Drivers module and defines cost and quantity of drivers; if disabled, the Drivers panel is not shown, and any mentioning of drivers disappears from notifications, user settings, and SMS dialog.
Eco driving
Activates Eco Driving tab in the Unit properties dialog, as well as the same-name table in reports. Besides, Eco driving app does not work without this service.
Еmail notifications
Allows you to send notifications by email. The service limit depends on the number of purchased licences. We recommend sending no more than 10 notifications per hour so as not to overload the server.
Еmail reports
Allows you to send reports by email. The service limit depends on the number of purchased licences. We recommend sending no more than 10 reports per hour so as not to overload the server.
Fleetrun
Activates access to the Fleetrun application.
Geofences
Activates the Geofences module and defines the cost and quantity of geofences; if disabled, the Geofences panel is not shown, and any mention of geofences disappears from reports and user settings.
Google (custom)
Allows you to regulate access to the Google maps, geocoding, and routing for the lower-level accounts. The service works with the key purchased from Google. With this service used, Google maps do not work in the Logistics application.
Google (standard)
Allows you to regulate access to the Google maps, geocoding, and routing for the lower-level accounts. The service works with the key purchased from Google. It is recommended to use this service and disable the custom one.
GPRS traffic
Allows you to control GPRS traffic through jobs, notifications, reports, and unit properties.
Groups of drivers
Defines the available quantity and cost of driver groups; works within the Drivers module.
Groups of geofences
Defines the available quantity and cost of geofence groups; works within the Geofences module.
Groups of passengers
Defines the quantity and cost of passenger groups; works within the Passengers module.
Groups of trailers
Defines the available quantity and cost of trailer groups; works within the Trailers module.
Hecterra
Activates access to the Hecterra application.
Import/Export
Enables access to the dialogs of import/export in the user menu; activates the Create from WLP button in the Units panel and the Export in file button in the unit properties dialog.
Jobs
Activates the Jobs panel and defines the available quantity and cost of jobs.
Locator
Activates the Locator option in the user menu.
Maintenance
Defines the available quantity and cost of the service intervals; if activated, the Service intervals tab appears in the Unit properties dialog, maintenance can be registered in the Monitoring panel, and the corresponding notifications and reports appear.
Management system
Access to CMS Manager.
Messages
Access to the Messages panel.
MGRS
The service allows you to activate the MGRS grid for Gurtam Maps.
Mobile notifications
Activates the corresponding action in notifications, as well as the tab in the Manage applications dialog (in user menu).
NimBus
Activates access to the NimBus application.
Notices to users
Allows you to receive notices from the administrator of the service.
Notifications
Activates the Notifications panel and defines the cost and allowed quantity of notifications.
Orders
Activates access to the Logistics application and allows to generate corresponding reports either on units or drivers.
Passengers
Activates the Passengers panel and defines the cost and quantity of passengers.
Profile
Activates the Profile tab in the Unit properties dialog and the same-name table in the reports.
Reports
Activates the Reports module and defines the cost and allowed quantity of report templates; if disabled, associated jobs and notifications disappear and the trip detector cannot be used.
Resources
Activates the Accounts panel in CMS Manager; defines the quantity and cost of resources and accounts.
Retranslators
Allows you to transmit messages from units to other servers and systems; activates the corresponding panel in CMS Manager; defines the allowed quantity and cost of retranslators.
Route rides
Allows you to create routes and defines the number of allowed rides and their cost (within the Routes module).
Route schedules
Allows you to create schedules and defines the number of allowed schedules and their cost (within the Routes module).
Routes
Activates the Routes module — enables the Routes panel and associated reports and notifications.
SDK
Activates access to Apps.
Sensors
Activates the corresponding tab and defines the number of sensors (calculated for all units in overall) and their cost.
Site access
Here you can allow/deny access to different sites within your system (like Wialon Mobile v2, extra sites, etc).
SMS messages
Activates access to SMS messages. In order to send SMS messages, the Can send SMS option should be activated in the user properties.
This service doesn't allow limiting the number of available SMS messages and specifying their cost for a billing plan or account.
Tachograph
Activates the Driver activity and Infringements tables in reports on drivers.
Toll roads
Activates the Toll roads mileage and Toll roads cost columns in the Trips report and adds the corresponding statistics fields in the advanced settings of a report template. The service uses the Platon toll system.
Trailers
Activates the Trailers panel and defines the cost and quantity of trailers.
Unit deactivation
Allows you to view the information about deactivated units. Top-level users and users with dealer rights are also able to deactivate units.
Unit groups
Defines the cost and quantity of unit groups.
Units
Activates the corresponding panel and defines the cost and quantity of units.
Users
Activates the corresponding panel and defines the cost and quantity of users.
Video
Activates the video surveillance mode.
Wialon Mobile (2)
Access to Wialon Mobile v2. If the mobile service URL is different from m.mos-glonass.com, it can be disabled only through the Site access feature.
Yandex (custom)
Allows you to regulate access to the Yandex maps, geocoding, and routing for the lower-level accounts. This service works with the key purchased from Yandex. If used, Yandex Maps do not work in the Logistics App.
Yandex (standard)
Allows you to regulate access to the Yandex maps for the lower-level accounts. This service works with the key purchased from Yandex. Geocoding, routing, and panorama are available for the service. For geocoding and routing you can set the allowed number of requests.
Yandex (standard) — geocoding
Activates the geocoding for the Address tool, the Monitoring panel, the Messages panel, and the application Logistics.
Yandex (standard) — panorama
Activates the viewing of panoramic images of the locality for Yandex Maps.
Yandex (standard) — routing
Activates the possibility of building routes by Yandex Maps for the Routing tool.
