Working with accounts and resources
You can work with accounts and resources only in the management system (CMS Manager). To get started, open the Accounts section in the navigation panel.
In the section, you can perform the following actions:
Accounts and resources are shown in standard tables. Working with them is described in detail below.
Table of accounts
By default, the section shows the table of all the available accounts. To open the table of resources, use the switch in the Search block.
To show or hide columns, click on the icon in the heading of the table with accounts. In the menu, the following columns are available:
Column Description
# The sequence number of the account in the table.
Name The name of the account in the system.
Creator The user on whose behalf the account was created. See more about the creator.
Account The parent account.
Billing plan The billing plan assigned to the account.
Dealer rights The dealer rights, if granted. The lines of accounts with dealer rights indicate Dealer.
Units The total number of all activated and deactivated units belonging to the account and its subordinate accounts, if any.
Activated units The total number of all activated units belonging to the account and its subordinate accounts, if any.
Balance The current balance of the account.
Days The number of days before the account is blocked, if blocking by days is configured for it. To see the date, point to the number of days.
The days can be highlighted in two colours:
  • black if the Block by days option is activated in the account properties;
  • grey if the Block by days option is activated in the properties of the account’s billing plan.
Status The status of the account: active () or blocked ().
If you have the required access rights, the icons also allow you to block or activate the account directly from the table.
Blocked The blocking date of the account, if it is currently blocked.
Contents The icon which allows you to run a quick report on the account contents.
Log The icon which allows you to open the log of the account.
Delete The icon red cross icon which allows you to delete the account. The icon is inactive if you don’t have access rights to delete it.
To open the properties of an account, click on its line in the table. Depending on your access rights, the window of the account properties may contain up to seven tabs.
Batch editing of accounts
You can edit some settings in the properties of several accounts at once. To do this, follow the steps below.
  1. Click on the icon   in the tool panel below the list of accounts.
  2. In the left list, select the account the properties of which you want to edit. To search for them, use the dynamic filter. To search by the name of the account, creator, parent account, billing plan, custom or administrative fields, select the corresponding option in the list above the search.
  3. Move the selected accounts to the right list by double-clicking them or using the icon  .
  4. Select one or more required actions from the three available ones:
    • Add payment or days. Allows you to change the balance of the accounts or add days (a comment is required).
    • Block/Activate. Allows you to block or activate the accounts.
    • Change billing plan. Allows you to assign another billing plan to the accounts.
  5. Click ОК.
Questions and answers
I want to assign a billing plan to an account, but it's not in the list. Why?
If a billing plan is not available in the Billing plan field of an account, it means that the account creator can’t manage this billing plan. To solve this issue, follow the steps below.
  1. Open the properties of the parent account.
  2. Navigate to the Restrictions tab.
  3. Move the required billing plan from the All billing plans list to the Assigned billing plans list. If the billing plan is not displayed in the All billing plans list, repeat these steps for the accounts which are higher in the hierarchy.
I want to assign a billing plan to several accounts, but it's not in the list. Why?
This happens if the creator of one or several accounts can’t manage this billing plan. Find the account for which you can’t select the billing plan and follow the instructions from the question above.
Table of resources
The table of resources contains all the available resources created manually. To open it, activate the Resources switch in the Search block and click on the Search button.
To show or hide columns, click on the icon   in the heading of the table with resources. In the menu, the following columns are available:
Column Description
# The sequence number of the resource in the table.
Select The selection of the resource.
Name The name of the resource in the system.
Creator The user on whose behalf the resource was created.
Account The account to which the resource belongs.
Log The icon which allows you to open the log of the resource.
To delete a resource, select it in the table and click on the icon   in the tool panel.
To open the properties of a resource, click on its line in the table. If you have the required access rights, you can work with the General, Access, and Custom fields tabs.
You can save the contents of any resource to a file or copy the required objects to another resource. Read more here.
