Queclink CV100LG: Configuration for Use in Wialon
This guide describes how to configure the Queclink CV100LG device for use in Wialon.
You can request Wialon trial account here.
Quick setup in Wialon
Use the following SMS commands to point the device to your Wialon account:
Command | Description |
1. AT+GTBSI=cv100,[apnname],[user],[pwd],,,,30,,,,,,,FFFF$ | Network mode: Auto; APN Authentication:PAP or CHAP. |
2. AT+GTSRI=cv100,7,,2,[wialon_IP],22197,,0,,5,1,,0,,,FFFF$ | Long-term TCP connection with the server. |
3. AT+GTFRI=cv100,1,,,,,,,30,,,,10,120,,,,,FFFF$ | Fixed time report every 30s/120s/10°. |
Video functions work only if the Password field is completed in the unit properties. The default password is cv100.
If you have further questions regarding the device configuration in Wialon, send the request to support@mos-glonass.com and specify the following details:
- device type and ID,
- issue description,
- configuration file, if applicable.
For ultimate technical support with hardware setup, we recommend contacting the device manufacturer.
Useful articles and links
Video
